servicedesk
Hi team,
I setup a custom return code in a "install" step and the deployment ends with this custom code but at the log appears in red.
If I consider a return code as success, why appears in red ?
servicedesk
Since I upgraded to v. 5238 this problem was fixed.
thanks
servicedesk
thanks
If you need further assistance, it might be best to troubleshoot via email instead. Contact support@lansweeper.com and provide:
  • Link to this forum thread.
  • Export of your entire Deployment\Logs page. You can hit one of the export buttons on the left.
servicedesk
Hi!
Same package, first one without the custom succes code "17025".
thanks
Bert_D
Could you provide us with a screenshot or export of the deployment log.
Thx
