Ertang
We are receiving the error "Preliminary checks failed! Task Service Error. Access is denied. (0x80070005 (E_ACCESSDENIED))" when we attempt to deploy any packages. I have verified that the credentials we are using are correct. I also tried the connection tester and it all comes back with no errors.
Has anyone had a similar issue? (I did submit a ticket as well)
thanks!
2 ACCEPTED SOLUTIONS
Ertang
looks like this is an issue related to 11.4.0.3 and they are working to deploy a fix.
FrankSc
Dear all,
We released 12.1 today, which contains a solution that solves the outstanding issue we had with deployments.
We regret the inconvenience this caused. You can find the new release on the page below:
Update your installation - Lansweeper
20 REPLIES 20
jwood-ok
Yeah I was getting that as well going from the change log.  I think I had to just go to the main page and act like I was a new user wanting to do the download.
jwood-ok
I updated to 11.4.0.4.  At first it wasn't showing anything on deployment log, but eventually it did and deployments seem to be working again.
PAL
in my case, nothing happens when I try to deploy. I have nothing new (in success or error) in the deploy logs since we updated to 11.4.0.3.
Is it related ?
FrankSc
Hi All,
We are working on a fix for this. Our goal is to make it available later today. Please keep an eye on our changelog.
Changelog - Lansweeper
Pealik
How long its 2 weeks and deploy not working. Its not okei!!!
PAL
you need to update to 11.4.0.4 and be sure that your Lansweeper server can reach app.lansweeper.com on port 443.
It is a bug, and I hope it will be fixed, but for now at least, it should help you resume deployment.
Let me know if it works.
PBri
Hi All,
i've updated this morning to 11.4.0.4 and it seems Deployment works good now, i've made some tests and i've 100% result OK.
Bye !
Pealik
Still not working even on version 11.4.0.4. I wonder why I pay this license if the software doesn't work as it should?
When will this mess be solved?
Sinan
Same here, we can not deply any packages along with patch tuesday packages
Ertang
Deployment Packages
Share topics/ issues related to deployment packages. Please use/rely on content with caution as it is publicly generated.
