‎08-13-2024 05:02 PM
We are receiving the error "Preliminary checks failed! Task Service Error. Access is denied. (0x80070005 (E_ACCESSDENIED))" when we attempt to deploy any packages. I have verified that the credentials we are using are correct. I also tried the connection tester and it all comes back with no errors.
Has anyone had a similar issue? (I did submit a ticket as well)
thanks!
Solved! Go to Solution.
‎08-13-2024 05:15 PM
looks like this is an issue related to 11.4.0.3 and they are working to deploy a fix.
‎08-15-2024 04:21 PM
Yeah I was getting that as well going from the change log. I think I had to just go to the main page and act like I was a new user wanting to do the download.
‎08-14-2024 11:25 PM
I updated to 11.4.0.4. At first it wasn't showing anything on deployment log, but eventually it did and deployments seem to be working again.
‎08-14-2024 04:45 PM - edited ‎08-14-2024 04:54 PM
in my case, nothing happens when I try to deploy. I have nothing new (in success or error) in the deploy logs since we updated to 11.4.0.3.
Is it related ?
‎08-14-2024 02:26 PM
Hi All,
We are working on a fix for this. Our goal is to make it available later today. Please keep an eye on our changelog.
‎08-27-2024 12:35 PM
How long its 2 weeks and deploy not working. Its not okei!!!
‎08-27-2024 02:55 PM
you need to update to 11.4.0.4 and be sure that your Lansweeper server can reach app.lansweeper.com on port 443.
It is a bug, and I hope it will be fixed, but for now at least, it should help you resume deployment.
Let me know if it works.
‎08-16-2024 08:18 AM
Hi All,
i've updated this morning to 11.4.0.4 and it seems Deployment works good now, i've made some tests and i've 100% result OK.
Bye !
‎08-15-2024 02:03 PM
Still not working even on version 11.4.0.4. I wonder why I pay this license if the software doesn't work as it should?
When will this mess be solved?
‎08-14-2024 11:28 AM
Same here, we can not deply any packages along with patch tuesday packages
