SB2021
Hello, everyone,
i created new deployment packages in lansweeper today. tried to assign this, but without success.
the installer logs are empty and the "deployment" index tab under the devices is not available.
In the past, you could always find out the status of the deployment here.
does anyone have experience how I can get it to work again?
The Lansweeper Connection Tester is successful, there are no problems here.
Thank you in advance!
EDIT:
for the sake of completeness, no deployments work at all, neither the previous nor the newly created one. unfortunately i haven't been able to isolate the problem so far. the index tab is also missing
Andy_Sismey
Was it working before you created the new packages, have you restarted the Lansweeper Service or Server ?
SB2021
small tip - big impact! works again! Thanks very much
Andy_Sismey
