‎02-25-2019 03:04 PM
‎02-25-2019 08:19 PM
‎02-25-2019 08:30 PM
JacobH wrote:
if you go into the asset page for a windows one, you should 'asset excluded from scanning' in red or something at the top next to the computer name or similar... do you?
If you do, then it won't get scanned anymore, but, the asset will remain in Lansweeper. I deleted them from my assets after excluding them
‎02-25-2019 04:19 PM
‎02-25-2019 08:15 PM
JacobH wrote:
are they scanned as a windows asset, or a 'vmware guest' asset?
if it's a vmware guest asset, you'll have to disable scanning of the ESX hosts, unfortunately.
I have this same issue - there's another thread on here about it... i think they are working on a better fix.
‎02-27-2019 09:17 PM
Actually after looking again, most are asset type Windows, only some were VMware guest.... so still not sure.
