saulob
This is my script:
Command:
Xcopy "{PackageShare}\Installers\uninstall.exe" c:\remotefolder /I /A /R /Y
Command:
Xcopy "{PackageShare}\Installers\executeFile.bat" c:\remotefolder /I /A /R /Y
Command:
c:\remotefolder \executeFile.bat
The bat files contains the uninstall command inside that execute the uninstall tool.
But the .bat file does not work. The uninstall.exe does not execute.
I tried one bat with a "msg * test ok" command and it does execute, tried one with a "dir > s.txt" but the s.txt file it's not created.
Why some commands execute on the remote machine and others not?
CyberCitizen
Honored Sweeper
It is hard to tell without seeing what your trying to uninstall, but I would go away from using a bat file as it won't pass error codes through etc. I would create it as a deployment package with each step etc so you can see where it's failing, its a little extra work at the start but makes things alot easier.
