bford
I am sure its a simple fix, but when I close a call and make it public the end user is often polite and replies with a Thanks", which then reopens the call and I have to close it again
How do I avoid this while still informing the end user that the call was closed
Thanks in advance
25 REPLIES 25
Mouaad
Any idea ?
Mouaad
Hi Pryan67,
Thank you for you help.
So If I understand well, I should open a ticket using a new email puting the key words 'Ticket closed' in it?
Mouaad
mouaad wrote:
Hi Pryan67,
Still receiving email even if I put the words Ticket closed...
pryan67
mouaad wrote:
mouaad wrote:
Hi Pryan67,
that's correct...you should have received the email, but no automatic ticket should have been opened. You also shouldn't receive an update in the ticket if the ticket is already open
Mouaad
Indeed no ticket is created when I put 'Ticket closed' in the body of the email.
But if the ticket is already created, then the mecanism seems not working properly.
pryan67
That should work fine then.
One issue we've had is the user replying to an older email, or replying without the text of the original email.
Try opening a ticket using a new email, but put the words ticket closed in the body of the email
Mouaad
pryan67
That should work fine. If you use the "test field" and put in ticket closed what are the results?
Mouaad
Thank you very much!
