mth111
how to do I change the IP Location field? I have it showing up on reports and on the asset listing but I need to change it. Edit option per asset does not appear to be an option. I need to change a lot of t
Ben-rutherford
Good Morning,
Easiest way to do this is to Hover over Assets  then click Edit Mode then you can bulk select assets and set their IP Location,
Other way  I think was to set the scanning target ranges with the location in.
