11-11-2024 09:10 PM
how to do I change the IP Location field? I have it showing up on reports and on the asset listing but I need to change it. Edit option per asset does not appear to be an option. I need to change a lot of t
11-12-2024 10:04 AM
Good Morning, Easiest way to do this is to Hover over Assets then click Edit Mode then you can bulk select assets and set their IP Location, Other way I think was to set the scanning target ranges with the location in.
