ewbarley
Anyone having trouble deploying the latest Java update jre-8u111/112? It appears to be silent? I have run the installer without LanSweeper and it has no prompts or windows for the typical install. Which means I am unable to extract the msi file. If I run it through Lansweeper deployment it gives an error. My previous Java deployments have worked very well.
AM13337
I was able to deploy it very smooth. My deployment does the following:
Step 1. Action Installer
Step Name - Install Java
Install File - \\File-Repo\jre-8u111-windows-i586.exe
Parameters - /s /lang=1033
Step 2. Remove Old Java
Step Name - Remove Old Java
Command - powershell -executionpolicy bypass -File "{PackageShare}\Scripts\Remove_old_java_versions.ps1"
ewbarley
I just tested jre8u112 and remove the /qn and /norestart options and the deployment completed without error...The previous version Java did not uninstall.
