Tim_N
We are excited to introduce a new learning path designed to help you get the most out of Lansweeper Discovery.
Lansweeper Discovery: Operate & Optimize is a five-part learning path created for Administrators. It guides you through preparing your environment, configuring your Hub and sensors, deploying IT Agents, and maintaining a healthy discovery setup over time.
Each course is concise and hands-on, with a clear goal: helping you collect accurate and reliable asset data from the start and keep your discovery running smoothly as your environment evolves.You will receive an email about this learning path, and you may also see a pop-up in the product inviting you to explore it.
👉You can access the full learning path at the Lansweeper Academy
We would love to hear how this supports your setup and where it helps you most.
Tim N.
0 REPLIES 0
