Danny_Summer
Lansweeper v12.5.3.0 manually add assets to scanning queue not working at all.
Lansweeper Server v12.5.3.0
LsAgent Windows v12.2.0.1
Katgroup
We have several reports of this, and our developers are investigating. It's been assigned the bug ID LAN-17701. Once resolved, it will be noted in our changelog:
9 REPLIES 9
PeterA
Does anyone know if downgrading to the previous version restores the ability to scan?
BCAKirkup
Rescans after deployments are not working either.
Katgroup
Is there any update or progress on this?
Katgroup
12.5.4.0 has been released to address this issue.
To update your installation to the latest version, please carefully go through the steps in this knowledge base article:
We always recommend making a backup before upgrading:
concarabo
Aslo an issue for us. Scanning ip ranges still works. For now if I need to do a manual scan I add the ip as a scanning target.
Steel_Shape
Same here. "Rescan Asset(s)" from a report will only scan the first asset of the report. If there is already one asset being scanned and you try to scan another, it won't queue the second one.
Ticket opened.
keenan
I also experience this. Scanning assets was not longer functioning, but it would work after a deployment.
Mister_Nobody
Honored Sweeper III
I have confirmed.
Do assets or report rescan and there are no assets into  the scanning queue.
