reggimenti_f
on the search bar, i've searched "project professional..".
there are 4 assets listed.
But there is no Project pro licence key inside the Recovered Licence keys of one of those assets
Why lansweeper is able to detect software, but not all the Product Keys? (we have the same problem with Autocad, just one PK is detected)
Is there a procedure to make it possible?
Thank you
Regards
If you want to scan license keys I suggest going through this knowledgebase article: https://www.lansweeper.com/kb/132/viewing-and-scanning-software-license-keys.html
The biggest problem with software and license keys is that there is no naming convention for software or license keys. This makes it very hard to match keys with the correct software. Therefore, from a Lansweeper point of view, software installations and software license keys are completely separate. More information about this can be found in this knowledgebase article: https://www.lansweeper.com/kb/133/software-installations-vs.-software-license-keys.html
