KHabershon
So I'm currently running 70 computer scans and 40 IP scans. I recently attempted to increase the number of IP scans that the server will run however I am getting the error below:
Limited to 99 total threads in MSSQL version.
Has this changed? I know before I was able to blow this number up as needed. How do I get this number to increase? I am using a full blown install of SQL so it's not SQL Express.
Your server is limited by default to 100 concurrent SQL connections.
In previous versions that didn't enforce this limit it caused database timeout problems when the threads were set too high. (you didn't notice the error but the scanned data didn't update)
