tgooden
Can Lansweeper give me logon and logoff history for users?
Not really by using the default features. Only logons during scans are stored by default.
You could do this using a report on eventlogs. Windows eventlogs you have enabled to import in the section Configuration==>Server options are stored in the table tblNtLog. Beware not to store the eventlogs to long in Lansweeper because storage of eventlogs significantly increases the size of your database.
