nriddick
Are there install switches for lsagent to automate the install to include the lansweeper server, port, and cloud relay auth key? I would like to put together a quick batch file for installation on my remote PCs
NicholeKaligian
When using the install switches, make sure to leave out the < and > symbols. If you're unable to get it working with the agentkey you've received from the web console, we'd recommend reaching out to support on support@lansweeper.com
lmosscornerston
It seems like the installer won't accept the --agentkey switch anymore, it gives an error "No such key AgentKey"
steveb
https://www.lansweeper.com/knowledgebase/silently-installing-lsagent-on-a-windows-linux-or-mac-computer/
