it_support2
We are currently trialing lansweeper with the free remote control tool, we have installed lsremote and use this fine but when selecting and expanding menus from start the menu are not appearing correctly.
The same also happens when right clicking the start toolbar menu etc.
We are running this on a Windows 7 PC and connecting via 1GB LAN so performance isn't the issue.
We have researched similar problems and people have suggested turning off aero etc but we cannot find any settings menu or ini file to do this through lsremote.
Has anyone got any suggestions or could advise if there is a configurable file that can be edited to resolve this.
dkhilo
I attempted to change the settings while logged into the server and the settings changed there were not reflected on the workstation.
I agree with others that this seems to be a user level setting, so this needs to be done on all machines the user will use.
This is what worked for me:
1. run \\{servername}\lansweeper$\lsremote.exe
2. click on the options button
3. change the options to the settings you want as default
4. click on the options button to close the options section
5. close lsremote(click on x in top right corner)
If I closed lsremote without clicking on the options button a second time, it would not save my settings.
dkhilo
FYI: you can edit these settings by running the lsremote executable directly (e.g. from the Program Files (x86)\Lansweeper\Actions folder on your Lansweeper server) and hitting the Options button. Editing the registry should not be necessary. If you run the executable directly, change your settings and then connect to a machine, your changes should be saved for any future connections.
satxx
We had the same problem but fixed it with a few registry keys under HKEY_CURRENT_USER - Software - Lansweeper - remotecontrol
Following keys are REG_DWORDS
TurboMode = 1
RemoveAero = 1
PoolWindowUnderCursor = 1
PoolOnEventOnly = 0
PoolFullScreen = 0
PoolForegraundWindow = 1
PoolConsoleWindowOnly = 0
There are more but these are the ones that fixed the updating/refresh issues for us. Hope it helps 🙂
Cheers
it_support2
Unfortunately we have tried this and it does not resolve the problem.
If refresh is pressed half the menus still look to be cut off??
Daniel_B
This is related to uVNC on which the remote control is based. Hitting the refresh screen button should help to get the remote screen updated in case menus are not displaying correctly.
