steveb
You can omit the shellrunas bits if it is not applicable to your environment. This lets you manage the printers on a remote machine similar to using print management but with a stripped down gui.
{actionpath}shellrunas /accepteula /netonly rundll32 printui.dll PrintUIEntry /s /t1 /c\\{smartname}
CyberCitizen
Honored Sweeper
Thanks, that worked. Not really useful for us, as we prefer print management.
But we have most of out remote site printers packaged and deployable now.
steveb
Leave off the bolded text and it should work.
CyberCitizen
Honored Sweeper
Did nothing for me, running it in DOS I get unknown command shellrunas
