AZHockeyNut
I have some VM's that are replicated. In the Summary page for a hyper-v guest it shows one host when there are multiple that show it. The STATE of a replicated hyper-v vm can only be powered on in one server at a time. So is it possible to make the system show the one where it is on? Not sure what you can pull back with LS and WMI or Powershell surrounding replicated VMs. I would think that VMWare would have a similar feature and this might already be possible but if not we can move this to a feature request.
AZHockeyNut
thanks Charles, so this field in the image where it shows the host is not an array or a list under the covers, it will only hold and display one value from the underlying query correct? assuming that is correct any chance it gets changed? 🙂 not really a big deal but was curious.
Currently Lansweeper can only detect if a Hyper-V guest is currently pingable. On the host asset page you will get an overview of the guests with the online status indicator next to it which is based on a ping at the time you open the web page. This ping is done from the web console to the asset. Lansweeper can't scan the state of Hyper-V guests as displayed in the Hyper-V Manager.
