Options
‎07-21-2014 06:57 PM
There are hundreds of assets that are no longer around anymore and I would like to remove them. Deleting them one at a time is time consuming. Is it possible to remove them any other way? Permanently delete assets not seen in the last is checked off and set to every 10 days but not sure if that is the same thing.
Solved! Go to Solution.
Labels:
General Discussion
Options
‎07-22-2014 07:45 PM
You can either:
- Use the cleanup options found under Configuration\Scanning Setup\Server Options to delete assets. Cleanups are performed when the Lansweeper service is started and subsequently every 24 hours.
- Manually delete multiple assets at once by clicking the Assets link at the top of the web console, ticking the checkboxes in front of the assets and hitting the Delete button on the left. You can filter one or more of the available columns to find the assets you need and tick the upper checkbox to select all assets in the current search results.
Options
You can either:
