‎01-11-2024 09:49 AM - last edited on ‎04-02-2024 10:53 AM by Mercedes_O
hi
for certain reasons we need to know which switch port is in use by which device, admin state etc.
so i created a report that displays all switch ports with the informations i need.
now i want to link the assets to the switch ports, but in doing so all ports with no device connected are not shown on the report anymore.
i posted my script below.
after adding tblsnmpassetmac and linking assetdit + ifindex to tbllsnmpinfo the devices are shown to the correct switch port, but as mentioned above empty switch ports are not shown anymore.
i tried to set up a condition for tblsnmpassetmac.assetmacaddress like:
Case When tblSNMPAssetMac.AssetMacAddress is NULL Then '1' Else '2' End
but i guess this isnt working because there is no entry in the table for this switch port at all, so i need a way to tell the system if you don't find anything just send back blank.
br
manuel
REPORT WITH ONLY SWITCH PORTS
Select Top 1000000 tblSNMPInfo.AssetID,
tblSNMPInfo.IfIndex,
Case
When tblSNMPInfo.IfAdminstatus = 1 Then 'Up'
When tblSNMPInfo.IfAdminstatus = 2 Then 'Down'
Else 'Testing'
End As [Port-Adminstatus],
Case
When tblSNMPInfo.IfOperstatus = 1 Then 'Active'
When tblSNMPInfo.IfOperstatus = 2 Then 'NotActive'
Else 'Testing'
End As [Port-Status],
tblSNMPIfTypes.IfTypename
From tblSNMPInfo
Inner Join tblSNMPIfTypes On tblSNMPInfo.IfType = tblSNMPIfTypes.IfType
Inner Join tblAssets On tblAssets.AssetID = tblSNMPInfo.AssetID
Inner Join tblDeviceRecognition On tblAssets.Assettype =
tblDeviceRecognition.Type
Where (tblAssets.AssetName Like 'MAYSW%' Or tblAssets.AssetName Like 'VMASW%')
And tblSNMPIfTypes.IfTypename Not Like 'loopback' And
tblSNMPIfTypes.IfTypename Not Like 'propVirtual' And
tblSNMPIfTypes.IfTypename Not Like 'other' And tblDeviceRecognition.TypeName
Like 'switch'
Group By tblSNMPInfo.AssetID,
Case
Else 'Testing'
End,
Case
Else 'Testing'
End,
tblSNMPIfTypes.IfTypename,
Order By tblAssets.AssetName,
tblSNMPInfo.IfIndex
Case
Else 'Testing'
Case
Else 'Testing'
From tblSNMPInfo
Inner Join tblSNMPAssetMac On tblSNMPAssetMac.AssetID = tblSNMPInfo.AssetID
And tblSNMPAssetMac.IfIndex = tblSNMPInfo.IfIndex
Like 'switch'
Case
Else 'Testing'
End,
Case
Else 'Testing'
End,
tblDeviceRecognition.TypeName,
tblSNMPInfo.IfIndex
Scanning
‎02-16-2024 02:47 PM
Manuel,
To include switch ports with no device connected in your report, you should use a LEFT JOIN instead of an INNER JOIN when adding the tblSNMPAssetMac
table. This will ensure that all switch ports are returned in the result set, even if there is no matching entry in the tblSNMPAssetMac
table.
Here's how you can modify your query:
Select
Case
Else 'Testing'
Case
Else 'Testing'
From
tblSNMPInfo
Inner Join tblDeviceRecognition On tblAssets.Assettype = tblDeviceRecognition.Type
Left Join tblSNMPAssetMac On tblSNMPAssetMac.AssetID = tblSNMPInfo.AssetID
Where
And tblSNMPIfTypes.IfTypename Not Like 'propVirtual'
And tblSNMPIfTypes.IfTypename Not Like 'other'
And tblDeviceRecognition.TypeName Like 'switch'
Group By
Case
Else 'Testing'
End,
Case
Else 'Testing'
End,
Order By
tblSNMPInfo.IfIndex
AssetMacAddress
will be NULL. You can then handle these NULL values in your report as needed to indicate empty ports.
