jroach
I have about 50 deployment scripts that I've made without any problem. Suddenly I would add a step and submit, then it just vanishes now. It was doing it half the time, now it does it every time. It's probably an easy fix but I gotta know what it is.
Next, I used to be able to roll out an installer to 4-500 people, and it would go 10 threads at a time or however many I have it set to. Now, whenever I try to rollout to a big report, it will stop logging (which is how I know I crashed it), and it won't deploy at all until I restart the services. Sometimes I can't stop the Lansweeper Service when this is happening and I just reboot the server... that works. Then I gotta go 50 or so at a time so I don't mess it up.
At this point I feel like I need to back up the database, fresh install, then import backup but the thing is I've already done that. So now what? Just start over, enter all new data?
jroach
Well, I fixed it. Cleaned the event logs and cleaned up database using DatabaseMaintenance.exe in Lansweeper\Tools..
This is something I try and do ever year or two. Makes LS run so much nicer but should auto do it.
