rinks
I have an open case regarding this, but want to see if anyone else has had success with installing IT Agent via an Intune package? We currently have LsAgent that was installed to our remote users with an Intune package, however we can't seem to get it working with IT Agent. Checking the forums, the two posts I was able to find on the topic are for LsAgent - Intune issues, but none with IT Agent - Intune.
On the Intune side of things, we (our IT Infrastructure team) gets an error stating "The system cannot find the file specified. (0x800700002)"
The install command is as follows:
Lansweeper-IT-agent-discovery-X.X.X-windows-x64-installer.exe --mode unattended --accepteula 1 --path "C:\Program Files\Lansweeper IT Agent Discovery" --cloudtoken ReallyLongKeyHere
----I found the issue just by typing this out...looks like they're using X.X.X instead of the actual version of the software like the instructions say. I will let them know.
FrankSc
Hello Rinks,
Our instructions mention indeed X.X.X in the example command, but indeed, this needs to be replaced by the version of the installer you are running.
Lansweeper-IT-agent-discovery-4.3.7-windows-x64-installer.exe for example.
Technically you can rename the exe to any other name you prefer, but you will have to use that name then also in your command.
