gnohs
Right now Im using the trial version, and maybe this is why I dont see the feature?
I want to password protect the access to the webconsole. I want to be able to add users with certain permissions, like view or configure user. Is this possible? Can I integrate it with my AD?
Daniel_B
First you need to enable user authentication on your website. Afterwards on the web console under Configuration\Website access define which user or AD user group should have access to which function. For details on how to use website access restriction, please refer to this KB article.
gnohs
Thanks so much for your reply.
Daniel_B
