aburrow
Has anyone been able to successfully scan Zebra printers. I'm looking to scan Model in particular but for some reason the SNMPBrowser provided by lansweeper and lansweeper itself is unable to scan. I've downloaded a 3rd party SNMPBrowser and it seems to work, but I cannot transfer the OID from it to lansweeper's SNMPBrowser as it uses names and not just numbers.
6 REPLIES 6
jasonlalanne
I managed to use and MIB browser to find the OID to scan.  We have a bunch of older printers that only show Zebra Printer, I see that you have one in your list also.
jasonlalanne
Can you do a MIB /SNMP walk with LanSweeper?
jasonlalanne
I used the Solar Winds MIB Walk app to find the correct OID to look for.
rom
Great!  Care to share your OID?
jasonlalanne
I see this is an old topic, has this been resolved?  We only see "Zebra printer"
rom
I'd need more info to help -  Zebra scanners work for me:
there's Zebra MIB's  for reference:  https://www.zebra.com/gb/en/support-downloads/printers/print-servers/zebranet-10-100.html
if no data shows up for the OIDs, you may have to do an snmpwalk and just scroll through the data that is returned
