We are using your premium app and it's very good for check our "a lot of many" company computers 🙂
I would ask your team, if poosible in future, to implement the function that the server uninstall automatically all not approved software.
You can add a checkbox where you can tell to the LanSweeper service to automatically uninstall selected and not approved software.
Sure normaly this checkbox should not be active and when you check it you must have also a dialog confirmation box 🙂
It's very boring to uninstall software manually, where you have to do this for too many computers in lan.
Stefano
