SEC_ALERTS
Hi Team,
We need one box in front of domain or workgroup to add the comment weather this is approved for not approved.
It would be easy to make the exception in network.
because in our environment some workgroup is allowed and other should disallowed.
if comment box would available ,I will simply ignore the approved domain or workgroup and take the action against unnecessary workgroup.
Thanks in Advance!!
Regards,
SEC_Alerts.
SEC_ALERTS
Thanks for your valuable reply.
Yes, we want only admin can do this.
We have added your feature request to our customer wish list. We would however recommend restricting access to the web console to ensure that only authorized admins can edit your configuration.
SEC_ALERTS
Please refer the attachment of snap and suggest the same.
Could you clarify where you would like to add these comments. In your configuration under Configuration/Scanning Setup/Scanning Methods? We would recommend restricting access to the web console to ensure that only authorized admins can edit your configuration. Instructions can be found on page 155 and beyond of our online documentation: http://www.lansweeper.com/documentation.pdf
