You can already do this in a way. What you can do is create a report which only displays assets which are near EOL. Then create an alert which gives back the report results. Depending on how you configure your report you can be alerted when assets are near EOL or have reached EOL.
The report below gives you an EOL overview of Windows 10 based on MS article (End of service for Home, Pro, and Pro for Workstation editions): https://support.microsoft.com/en-us/help/13853/windows-lifecycle-fact-sheet
You can create something similar report which and put
alerts on it.
tblAssets.AssetID,
tblAssets.Domain,
tblAssets.Username,
tblAssets.Userdomain,
tblAssets.IPAddress,
tblAssets.Description,
tblAssetCustom.Manufacturer,
tblAssetCustom.Model,
tblAssetCustom.Location,
tsysIPLocations.IPLocation,
tsysOS.OSname As OS,
tblAssets.Version,
tblAssets.SP As SP,
tblAssets.Firstseen,
tblAssets.Lastseen,
tblAssets.Lasttried,
Case
When tblAssets.Version In ('1507', '1511', '1607') Then 'red'
When GetDate() > '09/10/2018' And tblAssets.Version = '1703' Then 'red'
When GetDate() > '09/04/2019' And tblAssets.Version = '1709' Then 'red'
When GetDate() > '12/11/2019' And tblAssets.Version = '1803' Then 'red'
When GetDate() > '09/09/2018' And GetDate() < '09/10/2018' And
tblAssets.Version = '1703' Then 'green'
When GetDate() > '09/03/2019' And GetDate() < '09/04/2019' And
tblAssets.Version = '1709' Then 'green'
When GetDate() > '12/10/2019' And GetDate() < '12/11/2019' And
tblAssets.Version = '1803' Then 'green'
Else '#008000'
End As foregroundcolor
From tblAssets
tblAssets.LocationID
Where tsysOS.OSname = 'Win 10' And tblAssetCustom.State = 1
Order By tblAssets.Domain,
tblAssets.AssetName
