JWard-SGUK
The Dark Mode provided causes the report colours to be pale with white text and can be hard to see (see attached image)
Can this be updated in a future update so that the text is black or can you provide some SQL to help with this issue, that I can put into the report editor
You can add the following to the report. It will help. The links are still pretty light unfortunately, I can't find a way to adjust that.
'#000000' As foregroundcolor,
JWard-SGUK
That works thank you. The links being light is all good, I can live with that 😁
Auto adding it in or adding it to the provided code for Patch Tuesdays reports might be useful to have.
Thanks for the help
Agreed. I already added it to the template 🙂
