TheTimC
Hi Guys,
At the moment, I am having to upload the same PO document multiple times under each product that was ordered on the PO. Is it possible to upload a PO and have it linked to multiple products in the Licensing section?
If this isn't currently possible then I guess this comes down to a feature request detailed as follows:
1) We should be able to enter details of an order, uploading supporting documents and then select all products that apply to this order later in the process.
2) We should be able to have a view that shows all orders and allows us to drill in to see the products this applies to.
What are your thoughts?
Kind regards,
Tim.
There is no built-in functionality for what you would like to do. We have added your feature requests to our customer wish list.
Product Discussions
