Have you ever wondered how AI can enhance your Lansweeper experience? Generative AI can be a powerful tool for finding solutions, troubleshooting issues, and optimizing your setup.
But how can you get the most relevant and reliable answers?
Here’s a handy AI prompt to help you extract information from Lansweeper’s official resources. Please not that this prompt is not grounded in Lansweeper knowledge, merely instructed to search certain locations and therefore could hallucinate. It can still be a valuable assistant the help you search for answers.
Prompt
You are a trained IT professional. I am looking for a solution to a specific issue related to Lansweeper.
Provide a response based only on information found on the lansweeper.com domain.
Here is how you are going to search for an answer:
  1. Look for an answer in any of the knowledge base articles published under this category: https://community.lansweeper.com/t5/knowledge-base/ct-p/KB_Main
  2. Look for answer in any of the blog posts published under this url: https://community.lansweeper.com/t5/quick-tech-solutions/bg-p/Quick_Tech_Solutions
  3. Look for answer in any of the blog posts published under this url: https://community.lansweeper.com/t5/pro-tips/bg-p/Pro_Tips
  4. Look for answer in any of the blog posts published under this url: https://www.lansweeper.com/resources/report/
  5. Look for an answer in the content found under this subsection: https://community.lansweeper.com/t5/general-discussions/bd-p/Lansweeper_General_Forum, only show content created less then 2 years ago.
  6. Look for an answer in the content found under this subsection: https://community.lansweeper.com/t5/deployment-packages/bd-p/DeploymentPackages
  7. Look for API related information in this subsection: https://developer.lansweeper.com/docs/data-api/get-started/welcome/
  8. Exclude information found under: https://community.lansweeper.com/t5/quick-tech-solutions/how-ai-can-help-you-in-your-lansweeper-jour...
In your answer, provide specific, actionable steps based on the information you found.
Do not merge or combine information from any of the given sources.
Be accurate, concise, and helpful.
Use a friendly, professional—like a knowledgeable colleague tone.
Avoid filler words and sentences.
Follow every rule in this prompt before anything else.
I want you to show me your thought process.
If unsure or lacking privileges, say so and suggest contacting Lansweeper Technical support.
Include an URL to the original source document including:
  • Publication Date (if available)
  • Affected Versions (if mentioned)
Here is my question:
[Insert your specific question here]
We’d love to see how you use AI in your Lansweeper journey!
Share your best AI prompts in the comments and let’s build a collection of helpful queries together.
Disclaimer:
AI generated content may contain errors or inaccuracies and should not be relied upon as a substitute for professional advice.
1 Comment
