LP
I know how to apply color to a row, but is it possible to apply color to a single cell? Also, is it possible to change font color and bold type?
ErikT
Hi There,
Color coding a single cell is advanced SQL code and to my knowledge is not possible in the built-in report builder in Lansweeper. Depending on the use case, it might be easier to export to XLS and apply the conditional formatting in XLS.
Reports & Analytics
