SAAcanders
Is it possible to query/display the drive encryption level (128, 256)? I'm not finding the option in any tables used in this query
https://www.lansweeper.com/resources/report/hardware/bitlocker-drive-encryption-audit/
Thank you!
bmart17
Same here.  I am trying to create a report that would show whether or not the drive is encrypted and for the ones that are encrypted whether it's 128 or 256 bit encryption.  Hopefully someone out there has the answer.
Obi_1_Cinobi
Hello there!
If you still need help or have any questions, we’re here for you! Please don’t hesitate to submit a support case by clicking here: https://www.lansweeper.com/contact/contact-support/
If you’re having trouble getting into the Support Portal, you can use this link instead: https://www.lansweeper.com/contact/contact-support-case/.
We’re happy to assist you!
Reports & Analytics
