Ismail
I am stumped, I tried to run a customized report that would show me the following:
All servers (Domain controllers)
All member servers (Non DC's)
All Workstations (NON Servers)
All portable Workstations
In that same report I would like to view the following of each Computer:
Computer name
IP Address
Operating system
Computer manufacturer
Would anyone be kind enough to give me the SQL Query that would allow me to obtain this report ?
7 REPLIES 7
TheWood
@lansweeper
This is almost a perfect query for me, i just need to add in the Model, Serial / Service Tag, Memory and CPU Number and Speed.
Any help will be greatly appreciated.
Regards
Matt
Use this
SELECT     dbo.tblComputers.Computername, dbo.tblComputersystem.Domainrole, dbo.tblComputers.Domain, dbo.tblComputers.LastknownIP,
dbo.tblComputersystem.Manufacturer, dbo.tblOperatingsystem.Caption
FROM dbo.tblComputers LEFT OUTER JOIN
dbo.tblOperatingsystem ON dbo.tblComputers.Computername = dbo.tblOperatingsystem.Computername LEFT OUTER JOIN
dbo.tblComputersystem ON dbo.tblComputers.Computername = dbo.tblComputersystem.Computername
Ismail
Lansweeper wrote:
Use this
This report works great but the problem is that the IP Address is empty.
Ismail
Doesn't seem to be giving out any report whatsoever
Cobra7
SELECT
FROM
INNER JOIN dbo.tblComputers ON (dbo.tblComputersystem.Computername = dbo.tblComputers.Computername)
That should do it. The only problem is I have not upgraded to 3.5 so I don't know the table for an IP address. Someone else should be able to plug it in pretty quickly.
Ismail
Yes, indeed I do 🙂
Cobra7
SO you pretty much want to see every Windows computer on the domain?
