chadsharp
I am trying to utilize the custom fields in Lansweeper. I am trying use the follow sql to update the custom1 field if the server name is server01. I'm not sure what I'm doing wrong.
use lansweeperdb
Update dbo.tblAssetCustom
set Custom1 = 'test'
Select tblAssets.AssetID, tblassets.AssetName, tblAssetCustom.AssetID, tblAssetCustom.Custom1
from tblAssets
Inner Join tblAssetCustom on tblAssets.AssetID = tblAssetCustom.AssetID
where tblassets.AssetName = 'Server01'
This script does not do what I intended, it updates all of the fields in tblAssetCustom when I only want to update where tblassets.AssetName = 'Server01'
The reason I am wanting to do this is I have a powershell script that I wrote that will read a .cvs file that is an export from the inventory system that lansweeper replaced and I need to be able to traverse that file and only update records based on specific conditions.
Any assistance would be greatly appreciated.
thanks
Chad
RCorbeil
Honored Sweeper II
Maybe something like this?
UPDATE
tblAssetCustom
SET
Custom1 = 'test'
FROM
tblAssetCustom
INNER JOIN tblAssets ON tblAssets.AssetID = tblAssetCustom.AssetID
WHERE
tblAssets.AssetName = 'Server01'
chadsharp
That did the trick. Thank you.
RCorbeil
Honored Sweeper II
UPDATE
tblAssetCustom
SET
Custom1 = 'test'
FROM
tblAssetCustom
WHERE
Reports & Analytics
