Options
‎06-01-2011 03:39 AM
I cant seem to figure out how to create a report that displays what MS software is installed with the product ID and Product Key (as seen in add remove programs), What OS with Product and ID Keys are on both the servers and workstations.
If this needs to be broken into two reports that would be fine, as long as I can track what is installed on what machine.
Thank you in advance.
Matt
Here is what I have so far, but need the Product Key and Product ID.
Select Top 1000000 tblComputers.Computer, tblSoftware.softwareName, tblSoftware.SoftwarePublisher, tblSoftware.softwareVersion From tblComputers Inner Join tblOperatingsystem On tblComputers.Computername = tblOperatingsystem.Computername Inner Join tblSoftware On tblComputers.Computername = tblSoftware.ComputerName Where tblSoftware.SoftwarePublisher Like '%Microsoft%'
Matt
Solved! Go to Solution.
Labels:
Report Center
Options
‎06-02-2011 12:47 AM
Thanks to the support team for replying to my email
. Below is what I am using to generate my report. I added the distinct command to remove duplicate entries.
Thanks again!
Matt
Select distinct Top 1000000 tblComputers.Computername, tblComputers.ComputerUnique, tblComputers.Domain, tblSoftware.softwareName, tblSoftware.softwareVersion, tblSoftware.SoftwarePublisher, tblSerialnumber.ProductID, tblSerialnumber.ProductKey From tblComputers Left Join tblSoftware On tblComputers.Computername = tblSoftware.ComputerName Left Join tblSerialnumber On tblSerialnumber.Product = tblSoftware.softwareName Where tblSoftware.SoftwarePublisher Like '%microsoft%'
Thanks again!
Matt
Options
‎10-13-2011 05:19 PM
OS can be added to the previous query like so:
Select Distinct Top 1000000 tblComputers.Computername,
tblComputers.ComputerUnique, tblComputers.Domain, tblOperatingsystem.Caption,
Left Join
Options
‎10-13-2011 03:21 PM
is it possible to add the operation system?
Options
Thanks again!
Matt
Thanks again!
Matt
