hotschumacher
Hey Lansweeper Community!
I'm kind of new around here and could use some help. I've run into a bit of trouble with a malware attack on our fileserver. It seems to be targeting Brazilian banks and likes to hide in \AppData\Roaming\EdgeCookie\x86\anim\sd or \AppData\Roaming\EdgeCookie\x86\anim\ud, running some nasty bank-related malware.
Here's my challenge: I want to set up Lansweeper to scan our workstations for specific files in these folders, or better yet, for specific MD5 hashes. It'd be super helpful for spotting those sneaky infected files hiding in plain sight.
If anyone could point me in the right direction or give me a step-by-step, that would be awesome. Thanks a ton in advance for your patience and help, and sorry for any English mistakes.
Cheers,
[Fernando]
David_GF
Hi @hotschumacher
Lansweeper does not scan MD5 hashes, but you can use the custom file and registry scans to find out what computers are hosting the malware:
https://community.lansweeper.com/t5/scanning-your-network/scan-registry-values-with-custom-registry-...
https://community.lansweeper.com/t5/scanning-your-network/windows-custom-file-scanning/ta-p/64272
Good hunting!!
Sweep that LAN, sweep it!
David_GF
Hi @hotschumacher
Good hunting!!
