I have edited the report you have posted here to give back a total of GB, how many that is free in GB and how many that is used in GB per asset, by using the Sum function in SQL. Therefore, we had to remove the caption of the diskdrive as it would otherwise still give back each drive separately. Additionally, as you requested, I have made two reports, one for servers and one for workstations, by filtering on the domain roles. Instructions for adding this report to your Lansweeper installation can be found
here. If you are interested in building or modifying reports, we do recommend:
- Reviewing some SQL tutorials, as the Lansweeper report builder is a standard SQL editor. If you know SQL, you know how to build Lansweeper reports as well. This seems like a good tutorial.
- Making use of our database dictionary, which explains in great detail what each database table and field stores. More information on the dictionary can be found here.
Report for Servers:Select Top 1000000 tsysOS.Image As icon,
tblAssets.AssetID,
tblAssets.Domain,
tblAssets.IPAddress,
Sum(Convert(Decimal(7,2),tblDiskdrives.Size / 1024 / 1024 / 1024)) As TotalGB,
Sum(Convert(Decimal(7,2),tblDiskdrives.Freespace / 1024 / 1024 /
1024)) As FreeGB,
Sum(Convert(Decimal(7,2),tblDiskdrives.Size / 1024 / 1024 / 1024) -
Convert(Decimal(7,2),tblDiskdrives.Freespace / 1024 / 1024 / 1024)) As UsedGB
From tblAssets
Inner Join tblDiskdrives On tblAssets.AssetID = tblDiskdrives.AssetID
Inner Join tblDomainroles On tblDomainroles.Domainrole =
tblComputersystem.Domainrole
Where tblDiskdrives.DriveType = 3 And tblDomainroles.Domainrolename In
('Stand-alone server', 'Member server', 'Primary domain controller',
'Backup domain controller')
Group By tsysOS.Image,
tblAssets.AssetID,
tblAssets.Domain,
tblAssets.IPAddress
Order By tblAssets.Domain,
tblAssets.AssetName
Report for Workstations:Select Top 1000000 tsysOS.Image As icon,
tblAssets.AssetID,
tblAssets.Domain,
1024)) As FreeGB,
From tblAssets
('Stand-alone workstation', 'Member workstation')
tblAssets.AssetID,
tblAssets.Domain,
tblAssets.IPAddress
tblAssets.AssetName
