novasam
I have not included SQL server 2005, 2012, and 2014 yet, just SQL 2008 and SQL 2008 R2 using the MS lifecycle page. Also SQL server 2000 is a different animal. I found it easier to pick a system I know has sql 2000 and use that to find the others.
Here is the link to the MS lifecycle page with all the SQL versions. I'll try and update this script later today.
http://support2.microsoft.com/lifecycle/search/?sort=PN&alpha=sql
tblAssets.AssetUnique,
tblAssets.Domain,
tsysOS.OSname,
tsysOS.Image As icon,
tblSqlServers.displayVersion As Edition,
tblSqlServers.skuName As License,
tblSqlServers.spLevel As SP,
tblSqlServers.serviceName As Service,
tblSqlServers.lastChanged
From tblAssets
Inner Join tblSqlServers On tblAssets.AssetID = tblSqlServers.AssetID
Where ((tblSqlServers.displayVersion = 'SQL Server 2008' And
tblSqlServers.spLevel < '3') Or (tblSqlServers.displayVersion =
'SQL Server 2008 R2' And tblSqlServers.spLevel < '2')) And
tblAssetCustom.State = 1
Order By tblAssets.AssetName,
Edition
Daniel_B
Moved this to the report center as you have already created the report.
novasam
Here is an updated version with 2005 and sql 2012. Would need to add 2014 a year after SP1 is released. Also will need to update the script as SP are released or expire for previous versions of SQL. For example in July 2015 2012 SP1 will EOL.
tblAssets.Domain,
tsysOS.OSname,
From tblAssets
Where ((tblSqlServers.displayVersion = 'SQL Server 2005' And
tblSqlServers.spLevel < '4') Or (tblSqlServers.displayVersion =
'SQL Server 2008' And tblSqlServers.spLevel < '3') Or
(tblSqlServers.displayVersion = 'SQL Server 2008 R2' And
tblSqlServers.spLevel < '2') Or (tblSqlServers.displayVersion =
'SQL Server 2012' And tblSqlServers.spLevel < '1')) And
Edition
Reports & Analytics
