There are a few recommended steps for preventive maintenance on your Lansweeper On-Prem Installation.
Updating your Lansweeper Application – It is recommended that you update your Lansweeper installation on a regular basis to ensure that you have the latest available patches installed and access to any new features that have been released. Lansweeper now includes an auto-update feature to help you stay up to date. For more information on auto-update, check out Enable the Lansweeper scan server to auto-update. If you still want to update manually, follow the instructions in this article:
Update Lansweeper On-premises
Updating your Lansweeper Infrastructure – To ensure optimal performance, security, and supportability, it’s important to keep your Lansweeper infrastructure aligned with the latest supported platform requirements. Staying current allows you to benefit from the latest product features, performance improvements, security updates, and compatibility fixes. You can review the requirements here:
Lansweeper installation requirements
Automated Database Cleanups – Regular database maintenance helps keep performance optimal by removing outdated data. You can set up automated cleanups by following this guide:
Perform Automated Database Cleanups
Manual Database Cleanup – If you need a more in-depth cleanup, you can manually clear specific tables to free up space and improve performance. This guide provides step-by-step instructions:
Clear Tables to Free Up Space & Improve Performance
Review Your Setup – It’s also a good idea to periodically check if your current Lansweeper setup still meets your needs. You can use this guide to assess whether your configuration is optimal:
Which Lansweeper Setup is Right for You?
No ratings
2 weeks ago
