amaro_morales
This morning i've done a clean installation of Lansweeper 3.5, i've registered and now, when i fill the fields [Active Directory Domains and Domain Credentials and reset the server, this information is not lost.
The problem is that the information that Lansweeer must collect from all my pc's and servers, doesn't appear in the tab Action Screen / Active Directory information. I've even rebooted the server, deleted some machines and registered again, .....
somebody could tell me anything.
regards,
Amaro Morales I.T. Department amaro_morales@race.es
10 REPLIES 10
amaro_morales
thank you very much.
i've changed the serial registration code, reset the server, deleted my Pc and now appears the Active Directory Information.
you're the best one.
amaro_morales
perfect, i tell u if it works,
thanks,
I've send you a PM, please let me know if it works.
amaro_morales
i've done it yet, first i deleted my computer and then i've executed lsclient.exe. The information from Active Directory information don't appear.
thanks,
The screenshots looked ok (I have deleted them)
Could you try using lsclient and see if this works?
You can click on "attach" after you make a forum post
amaro_morales
how can i send you the screenshots???
thanks,
Could you please post screenshots of your configuration (active domains,filtered ou's,alternate credentials, website)
amaro_morales
I've registered Lansweeper with the Licensekey that i downloaded when i bougth the product (two days ago) v.3.5.
The file errorlog.txt placed in C:\Program Files\lansweeper\Service only have two lines:
11/03/2009 09:59:54: Database connection successful, starting up service
11/03/2009 10:55:24: Database connection successful, starting up service
thanks,
