poweld1
Where can I find the new active directory users group membership information?
Yes, the report lists your users and the user groups they belong to. Note that this report is only compatible with the 5.1 beta. You can scan users with the Domain User Scanning method found under Configuration/Scanning Setup/Scanning Methods.
poweld1
Thanks.
poweld1
Should I expect to see which groups a user is a member of?
Technut27
Great report, this will be useful for auditing purposes.
This information is listed on user webpages, which you can locate by typing a username into the search bar or using, for instance, the Active Directory Users OU widget. You can also run custom reports. A sample report can be seen below.
Select Top 1000000 tblADusers.Username,
tblADusers.Userdomain,
tblADusers.Firstname,
tblADusers.Lastname,
tblADusers.Name,
tblADusers.Displayname,
tblADusers.OU,
tblADusers.Lastchanged,
tblADGroups.Name As [Group],
tblADGroups.Description As GroupDescription
From tblADGroups
Inner Join tblADMembership On tblADMembership.ParentAdObjectID =
tblADGroups.ADObjectID
Inner Join tblADusers On tblADMembership.ChildAdObjectID =
tblADusers.ADObjectID
Order By tblADusers.Userdomain,
[Group]
