After the upgrade I now get these errors:
24.04.2009 11:04:22: Database connection successful, starting up service
24.04.2009 11:04:24: LDAP://CN=NTDS Settings,CN=dc03,CN=Servers,CN=Site01,CN=Sites,CN=Configuration,DC=domain,DC=local No ServerReference value at System.Collections.CollectionBase.System.Collections.IList.get_Item(Int32 index)
at System.DirectoryServices.PropertyValueCollection.get_Item(Int32 index)
at LansweeperService.LS_ActiveDirectory.EnumerateDomainControllers(LS_Domain Mydomain)
24.04.2009 11:41:50: domain.local dc04 The server is not operational.
24.04.2009 11:59:08: domain.local dc05 The server is not operational.--
I guess the dc04 and dc05 actually could have some issues, but we have 198 other working DCs out there. Why can't we set a spesific DC or AD Site for the LDAP queries?
The Active Scanning and OU filter is now actually working with the 3.5.1 beta
, but I get the following scan error on some of the test clients:
Scan Error Time
Wmierror The RPC server is unavailable 0x800706BA (testclient01.domain.local, TESTCLIENT01, 10.40.26.100) 24.04.2009 11:40:58
Wmierror Cannot connect to DCOM port 135 : Firewalled? (TESTCLIENT01) 24.04.2009 11:40:58 --
Could be a local firewall here (as assumed in the log). Remote WMI test also fails with the following errors against the same test client:
Remote WMI test
The RPC server is unavailable. (Exception from HRESULT: 0x800706BA)
The RPC server is unavailable. (Exception from HRESULT: 0x800706BA)--
Another test client is working fine:
Remote WMI test
Found: Microsoft® Windows Vista™ Business Service Pack 1
Found: Windows Vista (TM) Business Service Pack 1
\root\default Remote WMI access test OK--
I will follow up and let you know how it works. I really miss an option to select a DC or AD site for the LDAP queries performed by LANSweeper. Is this possible? If not - where can I send this feature request?
