In the past there was an utility called lstrigger that could be used to trigger the scan of a computer. I was trying to use it to scan assets but it does not work. Is it possible to modify the utility to scan printers or assets?
I'm still struggling because of the DHCP enabled printers, it's quite difficult to add more than 200 printers in a manual way, as I can't scan all the network. I've found a workaround for populating the right IP address according to its DNS, but I still need to add the printers.
Or if you explain me how you do it in the SQL side, I can program it myself.
