dkhilo
Getting "0 assets added to scanning queue" while doing rescan assets in a custom report I built. If i use some of the included reports like memory or disk status checks they seem to work correctly.
Just updated today(1/29/13) and it stopped working, Website Version is 5049 and 5.0.0.48,was previously on Website Version 5046 and 5.0.0.44 and it worked correctly.
We will issue a fix in our next update so you don't have to assign the AssetID alias to upgrade_tblComputers.Computername.
CHP-Pete
Try assigning the AssetID alias to the upgrade_tblComputers.Computername field.
You need to include either tblAssets.AssetID or upgrade_tblComputers.Computername in your report.
dkhilo
Noticed another user having this issue and was suggested to add the field assetid, I'm using the upgradetbl_computers view, how do I link to assetid from this view? What views/tables do I need?
Please contact us at support@lansweeper.com and provide us with screenshots of the problem.
