bungargp
When I select a computer to see the Action screen I have nothing listed under Advanced Actions. When I go into the Configuration screen I do have several items checked as being Advanced items...and I am faily sure I never changed the default settings from the original install or the upgrade to version 4. Why do these actions not appear under advanced actions?
Thank you!
Previous version didn't have advanced actions so it's normal if you upgrade to see all actions as "basic actions"
