Options
‎04-11-2018 10:52 AM
The report below lists your assets and their asset custom field values. Info on configuring and adding data to asset custom fields can be found in this knowledge base article.
Keep in mind that:
The report will only list assets that meet the following requirement:
Keep in mind that:
- Asset custom fields retain their original Custom1-Custom20 names within the Lansweeper database, regardless of what you set their display names to in the web console. To assign your preferred display names within the report, use aliases. Do not rename the fields within the database itself, as this will break your installation.
- Asset custom fields retain their original field type (i.e. text) within the Lansweeper database, regardless of what you set their display type to in the web console. If you want to process custom field data in certain ways, to perform calculations for instance, convert the field values within the report.
- The asset state is set to "active".
tblAssets.Domain,
tsysAssetTypes.AssetTypename As AssetType,
tblAssets.Username,
tblAssets.Userdomain,
tblAssets.IPAddress,
tsysIPLocations.IPLocation,
tblAssetCustom.Manufacturer,
tblAssetCustom.Model,
Coalesce(tsysOS.OSname, tblLinuxSystem.OSRelease, tblMacOSInfo.SystemVersion)
As OS,
tblAssets.SP,
tblAssets.Lastseen,
tblAssets.Lasttried,
tblAssetCustom.Custom1,
tblAssetCustom.Custom2,
tblAssetCustom.Custom3,
tblAssetCustom.Custom4,
tblAssetCustom.Custom5,
tblAssetCustom.Custom6,
tblAssetCustom.Custom7,
tblAssetCustom.Custom8,
tblAssetCustom.Custom9,
tblAssetCustom.Custom10,
tblAssetCustom.Custom11,
tblAssetCustom.Custom12,
tblAssetCustom.Custom13,
tblAssetCustom.Custom14,
tblAssetCustom.Custom15,
tblAssetCustom.Custom16,
tblAssetCustom.Custom17,
tblAssetCustom.Custom18,
tblAssetCustom.Custom19,
tblAssetCustom.Custom20
From tblAssets
Left Join tsysOS On tsysOS.OScode = tblAssets.OScode
tblAssets.LocationID
Left Join tblLinuxSystem On tblAssets.AssetID = tblLinuxSystem.AssetID
Left Join tblMacOSInfo On tblAssets.AssetID = tblMacOSInfo.AssetID
Where tblState.Statename = 'Active'
Order By tblAssets.IPNumeric,
tblAssets.Domain,
tblAssets.AssetName
Labels:
Finished Reports
Report Center
0 REPLIES 0
