Wyrembelski
Hello. I installed Lansweeper onto a server at work in order to test it. I chose the use Lansweeper built in database option, Installed the SQL server, and everything worked just fine. But now I want to uninstall Lansweeper and Reinstall so that I can use IIS for my web.
What would be the best way to go about this?
Is there any specific order I need to go in?
Or will it even matter since I will be using IIS now instead of the built in feature?
Because when I uninstalled and tried to reinstall on a test workstation a lot of problems occured.
Thanks!
Danny
Don't uninstall.
Run the installer, select new installation and select only the website to install, then choose IIS
