Optilan
When i click on a computer, it brings up the computer action screen, everything is fine apart from near the bottom of the screen where i get:
Computer model by vendor |
System.Data.SqlClient.SqlException: Invalid column name 'computer'.
System.Exception: The DefaultView was requested but no tables yet exist.
at DreamweaverCtrls.DataSet.get_DefaultView()
I know the error must be a field in a database somewhere i just dont know what to do with it? delete it?
Help appriciated.
Thanks.
Optilan Communication Systems www.optilan.com
Optilan
yes it did thanks Geert you big legend you.
Could you try the patch from this post http://forum.lansweeper.com/yaf_postst375_No-NTFS-filesystem-errors.aspx (latest upload at the bottom)
Please let me know if this fixes the problem
