Fes
i was wondering if there is a way where i can check
if i need to update or if the fixes are not top priority for me.
Like CVE-Numbers for Lansweeper.
We do not currently use CVE numbers and I'm not sure whether this is something we will implement, but all changes are logged on this page. We don't explain every fix in great detail, but the affected component (deployment, warranty scanning etc.) is usually mentioned, so you should certainly update if you're using the components mentioned.
